Radar Pulse to Pulse phase stability
Romansh
Member level 3
Hello,
I'm looking for the equation that converts Radar signal phase pulse to pulse stability from degree to DB (e.g. how much is 4°pk-pk in dB).
I couldn't find anything through google search.
Thank you in advance,
R
biff44
Advanced Member level 5
New England, USA
pulse to pulse should not matter at all, UNLESS you are coherently combining the received data from multiple pulses. what are you doing?
Romansh
Member level 3
Yes, this is what our customer is doing. I have spec that says 4deg pk-pk pulse to pulse phase stability, however our measurement equipment showing results only in dB.
So I need to find a conversion formula.
R
vfone
You cannot get phase information from dB measurements.
Romansh
Member level 3
This is not true, you can express phase difference in logarithmic form without loosing the information. I was thinking about Phase[dB]=20LOG10(Phase[deg]*Pi/180). Thus for 4deg peak to peak stability it will be equal to ~-30dB.
Please explain why the above is can't be correct.
biff44
New England, USA
where did you get that formula from? It is pretty meaningless to me.
are you trying to ask about subclutter visibility?
Romansh
Member level 3
The formula is for converting Integrated Phase Noise from deg to DB. So, my question is, if this formula is also applies to Pulse to Pulse stability, if not does anyone know the right one?
Again, I'm not asking for the meaning and the purpose this measurement, its just that there are 2 types of equipment that doing that kind of measurement some of them providing results in dB and some of them in dBc and I need the conversion formula.
