"Template based postprocessing result" error
mziium
Newbie level 1
Hi everyone,
I encountered this error after simulating a patch antenna in CST using T-Solver:
Template based postprocessing result "zline1(1).sig":
Error in calling "Evaluate1D" function (Unable to read result file: D:\patch\Result\zline1(1).sig)
Any hint please?
Hi
What exactly you have defined in your template based post processing window?
It may be due to the reason that function defined in template is not correct and not match with the data generated by simulation
