DarkInsanePyro
Newbie level 5
Hey everyone. I have a few more questions regarding VHDL and the quirks it seems to come with. I am -still- working on the ALU design that I posted about before but I changed my approach quite a bit. Eventually I will have to give up and declare everything manually but I wanted to make the design as dynamic as possible. Unfortunately the first change was converting the functions into components to grant flexible number of outputs rather than declaring a new custom type record. This came with a problem, where components cannot be utilzied in a process block which makes sense. Had to learn about generators (generate).
The current main issue staring me in the face is partial signal assignment where I want to assign a value to a sub-portion of a vector signal. The remaining unset bits will be asserted a value with the "others" keyword. This makes sense in my head but the compiler isn't liking it and I was hoping you could help me.
This is the code that I am having trouble with. The problem is that I am not sure how to synthesize an expression which will assert A to int_valuematrix where the value of "n" will declare the offset from right justification. I swear all the examples online are simple and have no potential to help in this situation, though it would help if you have a good (better) resource. I don't feel like I am doing anything crazy yet though I could be wrong.
The current full source code as it stands in a non-working condition... just for reference if need be.
Sorry if there is missing information. Wrote this post a while ago but campus seems to have connection issues to your server especially during posting.
library ieee;
use ieee.std_logic_1164.all;
entity Multiplier is
generic(
WidthA : integer := 3;
WidthB : integer := 3
port(
-- inputs
A : in std_logic_vector(WidthA-1 downto 0);
B : in std_logic_vector(WidthB-1 downto 0);
-- outputs
Q : out std_logic_vector((WidthA+WidthB)-1 downto 0)
end Multiplier;
architecture Multiplier_RTL of Multiplier is
-- Component Dependencies
component Adder
generic (
Width : integer := 3
port (
A,B : in std_logic_vector(Width-1 downto 0);
Cin : in std_logic;
Q : out std_logic_vector(Width-1 downto 0);
CarryBus : out std_logic_vector(Width downto 0);
Cout : out std_logic
end component;
-- Local Type Declarations
subtype ExtendedBus is std_logic_vector(WidthA+WidthB-1 downto 0);
type ValueMatrix is array (WidthA+WidthB-1 downto 0) of ExtendedBus;
type SubresultMatrix is array (WidthA+WidthB-1 downto 0) of ExtendedBus;
--subtype InputTerm is std_logic_vector(WidthA-1 downto 0);
--type DataMatrix is array (WidthA+WidthB-1 downto 0) of InputTerm;
-- Internal Signals
signal int_valuematrix : ValueMatrix;
signal int_subresultmatrix : SubresultMatrix;
begin
-- generate the value table
gen_values: for n in B'reverse_range generate
int_valuematrix(n)(n+A'left downto n+A'right) <= A;
int_valuematrix(n) <= (others => '0');
end generate;
Q <= int_valuematrix(1);
-- generate the masking table which enables/disables each adder 'cell'
--gen_mask: for n in 2 downto 0 generate
-- int_maskmatrix(n)(n+WidthB-1 downto n) <= (others => B(n));
-- int_maskmatrix(n) <= (others => '0');
--end generate;
-- generate the table of additions
--u1: Adder generic map (Width => 3) port map(A=>"000"&A, B=>int_maskmatrix(0), Cin=>'0');
end Multiplier_RTL;
--= FullAdder
library ieee;
entity FullAdder is
port(
-- inputs
A, B, Cin : in std_logic;
-- outputs
Q, Cout : out std_logic
end FullAdder;
architecture FullAdder_RTL of FullAdder is
begin
Q <= A xor B xor Cin;
Cout <= (A and B) or (A and Cin) or (B and Cin);
end FullAdder_RTL;
--= Adder
library ieee;
entity Adder is
generic(
port(
-- inputs
A, B : in std_logic_vector(Width-1 downto 0);
Cin : in std_logic;
-- outputs
end Adder;
architecture Adder_RTL of Adder is
signal int_carry : std_logic_vector(Width downto 0);
signal int_result : std_logic_vector(Width-1 downto 0);
component FullAdder port (A,B,Cin : in std_logic; Q,Cout : out std_logic); end component;
begin
int_carry(0) <= Cin;
gen: for i in Width-1 downto 0 generate
fa: FullAdder port map(A=>A(i), B=>B(i), Cin=>int_carry(i), Q=>int_result(i), Cout=>int_carry(i+1));
end generate;
Q <= int_result;
Cout <= int_carry(int_carry'left);
CarryBus <= int_carry;
end Adder_RTL;
--= Inverter
library ieee;
entity Inverter is
generic(
port(
-- inputs
A : in std_logic_vector(Width-1 downto 0);
-- outputs
end Inverter;
architecture Inverter_RTL of Inverter is
signal mask : std_logic_vector(Width-1 downto 0) := (others => '1');
begin
Q <= A xor mask;
end Inverter_RTL;
--= Multiplier
library ieee;
generic(
port(
-- inputs
-- outputs
end Multiplier;
component Adder
generic (
port (
Cin : in std_logic;
end component;
-- Internal Signals
begin
end generate;
--end generate;
end Multiplier_RTL;
--= Top Level - SimpleALU
library ieee;
entity SimpleALU is
port(
-- inputs
A, B, S : in std_logic_vector(2 downto 0);
-- outputs
Q : out std_logic_vector(5 downto 0);
O : out std_logic;
C : out std_logic
end SimpleALU;
architecture SimpleALU_RTL of SimpleALU is
component Adder
generic (
port (
Cin : in std_logic;
end component;
component Inverter
generic(
port (
A : in std_logic_vector;
end component;
component Multiplier
generic(
port(
Q : out std_logic_vector(WidthA+WidthB-1 downto 0)
end component;
signal int_carrybus : std_logic_vector(3 downto 0);
begin
-- u1: Adder port map(A=>A, B=>B, Cin=>'0', Q=>Q(2 downto 0), CarryBus=>int_carrybus);
-- u2: Inverter port map(A=>A, Q=>Q(5 downto 3));
-- C <= int_carrybus(int_carrybus'left);
-- O <= int_carrybus(int_carrybus'left) xor int_carrybus(int_carrybus'left-1);
u1: Multiplier port map(A=>A, B=>B, Q=>Q);
end SimpleALU_RTL;
