Engineer4ever
Member level 3
- Joined
- Feb 2, 2013
- Messages
- 67
- Helped
- 1
- Reputation
- 2
- Reaction score
- 1
- Trophy points
- 1,288
- Activity points
- 1,748
I have a couple of questions about the PFD and the CP and I hope someone can help me:
1) How can I determine the required PFD range? In other words, is there a way to know if I should use a PFD which has a range from -2pi-->2pi or if it's enough to use a PFD circuit which has a range of -pi-->pi? How can I control that, if that could be controlled?
2) As far as I know, Ring VCO usually requires differential control voltage, which means that I should design a differential charge pump and two loop filters for each output and I already read that in many papers and references, but my project supervisor was shocked when I told him that and he said that no one does that, and that the Ring VCO needs a single control voltage. So, is it true or not?
Thanks in advance,
Thanks in advance,
