walters
Advanced Member level 2
Slew rate rise time
Is Slew rate a delay or offset from input to output?
Why don't transistors have slew rate?
If u input a Square waveform into a op-amp the slew rate makes the output "linear" to measure the upper and lower limits
If u input a exponential waveform or voltages does the slew rate change the exponential waveform into a "linear" voltages or waveform?
Does the Slew rate only affect the high frequencys?
Does the Slew rate change the input waveform into a Linear waveform?
Because the Slew rate produces a "Rise time" delay
