questions about pipeline adc mechanism
airboss
Member level 3
i've seen this block diagram for pipelined adc in many places but i'm really confused. please help me to understand this. we know this will be implemented by S/H capacitor circuit.
1)we see a 2X here. i guess this is because of capacitor charging transferring from sample phase to holding phase. is this correct?
2)many books mention that Vout = 2Vin-Vref. however, from the diagram i uploaded, it seems to me Vout=2*(Vin-Vref). what is my mistake? i know subtraction of output from DAC is done in holding phase. or should Vout=2*(2Vin-Vref)?
thank you!!
mince
Member level 5
Texas
If you look at the topology of the MDAC and do the analysis on the switch cap circuit, you can find that the output will be Vo = 2Vin - Vref for the 1.5 bit/stage architecture.
    airboss
satyasiva
Full Member level 1
this fig. does not correspond to 2vin-vref. it is for 1.5bit/stage.
    airboss
ronialeonheart
Junior Member level 1
The Vout = 2Vin-Vref mentioned by many books is not the Vin in this diagram. You can comprehend it as this, the first stage: Vout1=Vin±Vref, second: Vout2=2Vout1±Vref, ..., and Vout1, Vout2, ..., are not the Vout in your diagram. It's the voltage at the left side of the ×2 block.
    airboss
