zhengchao201105
Member level 2
may be I should sodering a pcb board using IR4426, but i should know the reason,so......
question 1:BAT is 12v,R600 is 100ohm,so it is ok,which value should I choose? according to the datssheet,max input bias current is 30uA,so R600 should be bigger than 12v/30uA=400Kohm?
question2:INA/INB is invert input,and have a internal 5v pull-up resistor,so I should add a resistor in series with INA,so R606=1K is small enough,does anyone have this experience which value is right?
