Questions about hfss_symmetry_plane
elektr0
Full Member level 5
Hallo,
we defined two lumped ports to excite a differential planar inductor, which is symmetric. Is it possible to delete half of the structure (even the second port) and just calculate one port ?
greets elektr0
Added after 5 hours 10 minutes:
The second question is, if there is only one port with calculation results. How do I get the whole S2P matrix.
Re: hfss_symmetry_plane
you can turn off one port in HFSS , fields, edit sources. if you want to delete the whole structure then i would just delete it and have 2 simulation files.
