mosgaard2000
Newbie level 3
I have tried to read about gated clocks in different posts, but haven't been able to find a good answer, so I create a new post.
I have a Clk_1 which I gate and call Clk_g. The block that runs on Clk_g read some signals from a block running on Clk_1.
My problem is I get some Hold-time violations because the outputs dissapears from the first block before the gated block can read it.
My output signals are only 1 clk wide - is that the problem and can it be solved or do I need to increase the width of the signal?
