Questions about Cascode Bandgap
pseudockb
Member level 5
Cascode Bandgap
Hi all, I have some questions regarding the cascode bandgap.
1. Could someone please explain to me how the start-up circuit works? My understanding is that the NMOS acts as a pull-down resistor to pull the voltage at the gate of Mpinj to GND so as to inject a current into the bandgap core. How does the start-up circuit turn off? Or is it operating at all times? How does Mpstart come into play?
2. What is the reason of connecting Q3/Q5 at the bottom of cascode biasing transistors?
3. I can diode connect transistors MP2 so that I can remove the M3 transistors to save a branch of current. Any bad effect of this?
4. Intuitively speaking, the PSRR of this bandgap is a resistive devision between the output impedance of the cascode current mirror and the R2. I have heard that bandgap circuit utilizing an opamp clamping the at the top of Q1 and top of R1 can achieve a better PSRR compared to the cascode bandgap. Why is it so?
Thanks.
mpig09
Full Member level 4
Taipei
Re: Cascode Bandgap
Dear :
1.When VDD rise to supply voltage(3.3V or 5V...)slowly, Mnstart will first on then other MOS, when Mnstart on, Mpinj will on, so the bandgap will into desired operation point.
==>for high accuracy.
3.remove the M3 transistors to save a branch of current.
==>that ok, when your design & calculate is right.
4. I don't understand.
Best Regards,
mpig
pfd001
Advanced Member level 1
Cascode Bandgap
M3 tansistors can not be removed. It provides bias for the PMOS transistors near the power supply
jjsnail
Junior Member level 1
Cascode Bandgap
M3,M5 provides biass for the cascode M1,M2
but I think we can use current miror with M1,M2 to save the bias. am I right?
corel
Re: Cascode Bandgap
1. I also can't understand how the startup circuit cut-off from the main circuit after it start
4. use opa is voltage negative feedback to make two nodes' voltage equal.
This circuit is use current negative feedback to realize two nodes' voltage equal.
But I can't explain how this current negative feedback work,Can somebody explain it?
davidwong
Member level 4
Re: Cascode Bandgap
Mpinj will be off after startup
Vgs of Mpinj will be close to 0V
as Mnstart is long channel device.
she_long
Junior Member level 3
Re: Cascode Bandgap
Hi, pseudockb
I think in the schematic the resistor R1 should be under the source of Mn1.
If that, for R1, Mn1 Mn2 Mn3 Mp1 Mp1cas and Mn1 consist of a negative feedback.
Mn3 can increase the open loop gain to increase PSRR.
waosai
Member level 2
Re: Cascode Bandgap
I think the following structure can move Mp3, Mn3, Mp5, Mn5, Q3 and Q5.
I don't know whether I am right.
niezimei
agree with she_long
change the polarity so as to make the whole circuit in negative feedback control.BTW, this circuit need a capciator which is added between the gate of Mn3 and gnd to make a dominate compensation.
liuyonggen_1
Full Member level 4
Re: Cascode Bandgap
first, M3 an M5 is used to bias the mp1 and mp2,respectively,which is very necessary for low power supply applications,because the voltage drop across the whole cascode current mirror is only 2 times Vov. that's to say, if the power supply voltage is large enough, you can use other structures to replace M3 and M5.
second, i think the start-up circuit is not good. in my opinion, it's difficult to turn off the current-injection banch. i suggest you use other start-up structures. there are many simple start-up structures.
fanrong
Banned
Re: Cascode Bandgap
she_long said:
Hi, pseudockb
If so , the loop gain will large than 1 , which will lead to unstable !?
devop
Full Member level 1
Re: Cascode Bandgap
there will always be I flowing through Mstart?
she_long
Re: Cascode Bandgap
fanrong said:
she_long said:
Hi, pseudockb
Yes, to the plus of R1, the loop gain will large than 1, but it's a negative feedback, it's the same in 'waosai's picture. R1 always in the negative feedback loop. That's more clearly in the BGR using an op amp.
