Questions about an opamp based integrator problem
OMEsystem
An integrator problem
Please refer to the attachment.
I have an opamp based integrator Fig.1, If I would like to analyze the loop
gain and its response, the schematic should be connected as Fig.2. (1) Is it right?
In addition to this, I have another question, If the opamp is replaced by an
OTA, do I need to count the feedback C when I calculate the phase margin
of OTA? If the OTA is single stage, (2) does the Feedback C helps the stability?
(3) Do I need to count the R when I calculate the phase margin of OPamp?
safwatonline
EGYPT
i think figure two shows a comparator,followed by diffrentiator , i dont see its relation with figure 1
nxing
Advanced Member level 1
China
figure 2 is not the equavlent circuit of Fig1. please check it more closely
pfd001
you can use fig.2 to simulate the open loop characteristic of the opa, where the input parasitic capacitance must be inclded in parallel with R.
OMEsystem
Re: An integrator problem
pfd001, thank,
I know you really know what I want.
By the way, Can we use the feedback C to compensate the opamp?
