doncarlosalbatros
Full Member level 2
I'm trying a build a strain gauge amplifier using this instrumentation amplifier: https://www.analog.com/media/en/technical-documentation/data-sheets/AD8221.pdf
Bridge is 350 Ohm full bridge and with a 5V excitation voltage.
The strain gage will be outputting +-2mV only.
After making some research I finalized the circuit as below:
The wires from gages to the amplifier will be around 15 meters long.
I would be glad to have your opinion about this circuit.
I have some questions in my mind and couldnt find an answer yet,
1-) How can I add some ESD protection and where in the circuit and which type of diode should I use? Any models which wouldnt effect the gage signals?
2-)I added RFI filter because this paper suggests: https://www.analog.com/media/en/technical-documentation/application-notes/AN-671.pdf Would that be enough for input signal noise? Should the wires be twisted?
3-)I want to use a RC LP filter before the data acquisition ADC. But should that filter be right after the inamp output or close to the ADC?
4-)+-5V voltage converter is a bit noisy in simulation and are the caps in this circuit enough for noise?
5-) I might need to make this circuit more versatile like adjustable gain or adjustable reference offset. But the pot I need to use must be very price to have a stable gain. And for the reference they warn not to use voltage divider. What IC I can use to adjust the ref voltage here? One of my fear is if I dont add a variable reference or gain and if they install the gage under a stress then my amplfiier in the schematic might saturate.
If you have any experience and extra suggestions I would be glad to hear. Thanks
