Question regarding system verilog
srish
Newbie level 6
i need to write a task which generates random binary data and write it in to a file? can anyone help me because i can not use randomize() method and rand longint because they can not be used without class declaration and my task is not under any class?
---------- Post added at 18:14 ---------- Previous post was at 18:12 ----------
i see $random function but it returns only 32 bit unsigned integer
dave_59
Advanced Member level 3
Fremont, CA, USA
You can use std::randomize(variable) on any variable regardless of whether it is declared in a class.
You can also use std::randomize(variable) with {constraints_on_variable} using the same constraints you could have declared in a class.
Reactions: srish
    srish
ljxpjpjljx
Shang Hai
yes , try to use std::randomize or std::randomize with method to generate random data!
Reactions: srish
    srish
srish
Newbie level 6
Thanku vrymuch ........it really worked out for me ..................but there z one question that if we can give seed to std::randomize(variable) ? and if yes then how can we pass seed value for randomization into this ?
