question regarding soc encounter
cyrax747
Full Member level 3
Bangalore
Hi
I am doing netlist to routing in soc encounter with reference to a manual given and it is very primary,so i did floorplan added phsyical cells and did placement.how to check the legality of pins macros cells etc? what is the command ?
2) while adding well taps and endcap cells there are fill2 4 6 cells for both tap and endcap cells list also.what fill num shud i take for tap cell ? an also while adding endcap ; for start and end row which fill num cell shud i use ?
3) i have only 4.78% of vertical congestion how to fix it in encounter ? what are the ways ?
