cosmo_kramer
Newbie level 2
Hi all,
I have a question regarding SDF values.
Lets say for a design I dump an SDF without any constraints.
I also dump an SDF by defining a 500Mhz clock on one of the ports.
I also dump an SDF by defining a 20mhz clock on the same above port.
There are no other constraints other than the clock.
Now which SDF has the worst delay numbers of the three?
This is important as I use SDF for PT as well as ATPG sim's.
Now if we dump SDF based on mode and corner we cannot use it for SIM as ATPG has multiple modes in one pattern. Namely [SHIFT-TFT] - [CAPTURE] - [SHIFT OUT]. Now if we dump with mode and corner that which SDF to use for ATPG.
Also Generally how are SDF's dumped for using in functional/DFT SIM's?
Appreciate your inputs.
