question regarding opamp- ac signal disappears
Akramin84
Newbie level 6
i got mixed signal ac and dc, i just want to amplify ac signal so i put coupling capacitor to filter dc. the problem occur ac signal disappear when i connect to the non inverting pin of opamp. anyone can give me solution ????
wht r u connecting to ur non inverting pin?
Re: question regarding opamp
i'm connecting to non inverting pin of the opamp.the volatge is 2.5 V dc and a few hundred mV. I just want to filter the dc part.but im still looking the right value and type of capacitor .whether tantalum ,electrolitic of ceramic...anyone can help me with this.....
Added after 22 seconds:
i'm connecting to non inverting pin of the opamp.the volatge is 2.5 V dc and a few hundred mV ac . I just want to filter the dc part.but im still looking the right value and type of capacitor .whether tantalum ,electrolitic of ceramic...anyone can help me with this.....
Please attach your circuit.
    Akramin84
It is a typical error: it is NOT allowed to place a cap directly in front of any opamp input.
The reason: No bias current can flow.
You must connect a large resistor to ground in addition.
thank you of all your help....i already solve the prob....instead of putting ceramic capacitor to filter dc , i put tantalum 47uf and everything work just fine.however ,i don't really understand the theory behind this dc filtering. how the value of capacitor affect dc voltage ? anyone can provide me with the reference ? .here i attach the circuit diagram..
There is no dc filtering, as dc is simply blocked. Therefore, the value of the cap has no influence on dc blocking. However, the cap value determines - together with resistor value - the corner frequency for ac performance.
oooo i see can you give equation regarding this matter ?????
The gain is: \[\frac{V_o}{V_i} = - \frac{R_2*C*s}{1+R_1*C*s}\] where s=j*w and j is the complex unit. So in complex form, you get: \[\frac{V_o}{V_i} = - \frac{R_2*C*j*w}{1+R_1*C*j*w}\]
So ploting the gain versus frecuency, you get something like this:
(This is just a descriptive image, the values are for another system or R and C values)
The label 'Frecuency' in the graph, is w = 2*pi*f, so, if you want the frecuency in Hz, you must calculate: \[f = \frac{w}{2*pi}\]
The frecuency w=100 in this graph, corresponds to the pole at \[w = \frac{1}{R_1*C}\] of your system, and the gain at high frecuencies is \[\frac{V_o}{V_i} = -\frac{R_2}{R_1}\], not 0 like in the graphic.
In a simple manner, the capacitor is a open circuit at low frecuencies, and a shorted circuit at high frecuencies.
Everything i wrote is true, only if you consider the operational amplifier completly ideal.
Regards, Diego.
By the way, "in the real world", if you want to reduce the DC level at the output, you must connect a resistor between the non inverting input of the Operational Amplifier, and ground, instead of connecting it directly to ground.
The value must be \[R_1||R_2 = \frac{R_1*R_2}{R_1+R_2}\].
