arunbhaskar
Junior Member level 3
I've built a wind turbine using 3ph permanent magnet alternator. For the wind speeds I get near the installed turbine, the voltage range is from about 10 to 50V (DC voltage after rectification). I've purchased a 12V lead acid battery. So I'm really confused as to what method of charging I have to incorporate.
Can someone suggest the best method for charging the battery for the given conditions..??
Also, I need to know what are the range of DC voltages that can be directly applied across the battery without any current limiting resistor for a 12 V lead acid battery.
