evoplus
Member level 1
I have some doubts regardin the Stephen A Maas, Microwave mixer which I hoped that you guys can help me clear of.
It mentioned that in the singly balanced mixer part that as both the applied RF voltage and the conductance wave forms are in phase, therefore all the voltage and current components, including the IF frequency must be in the diode. Thus the IF current combine at the node that are joining the diodes.
Question: How does the both the applied RF voltage and the conductance wave forms are in phase? How does the IF appears in the diode?
However the scenario would be different for the LO noise-voltage components shown in figure 2.2(b), these who enter the mixer at the LO port would have a 180° out of phase at the diode. The resulting IF current would be out of phase and be cancelled at the IF output. Therefore as long as the mixer is perfectly balanced, the AM LO noise and the AM spurious signals on the LO would be completely cancelled.
Question: Could someon explain how does the AM LO noise and the AM spurious signals on the LO would be completely cancelled?
Thanks
Thanks
