question on sigma-delta modulator
abcyin
Full Member level 4
Hi, all,
I am a very beginner on this topic (sigma-delta modulator), so could you anyone tell me that, in the following figure, how to choose the values for VREF+ and VREF-, and why?
Thanks very much in advance!
YooCanFly
Newbie level 3
i dont think there is a hard rule on vref+ and vref-
it would also depend on what order your ADC is. For a simple 1 bit ADC,
general rule of thumb is about 70% and 30% of your supply voltage.
(assuming 0-supply voltage is your input range)
I dont know if this is a good explanation, but let me give it a try.
you want to integrate the difference between input and vref, so you want (input - vref) to be as big as it can be to help the integrator reach 0.
For that, its better to choose vref+ to be between 50% to 100% of your supply
and vref- to be between 0 to 50%.
well, i would think the best results are achieved at 75% and 25%, but during my simulation long ago, i found best results at 70% and 30%.
I hope this helps.
mikersia
Full Member level 2
In this SDM configuration (VREF+ - VREF-) will define maximum voltage swing both at the x input and integrator's output. VREF- could be zero.
nelson_analog
USA
For this circuit, the Vref+ and Vref- must be one is positive and one is negative since the reference of comparator is 0. You can check book for how to decide the reference.
spree2007
Newbie level 2
Vref+ and Vref- set the feedback factor
in your case, I think connect them to vdd and gnd is ok and convenient
