Register Log in
Question on receiving antenna impedance matching
yashiro32
Member level 1
Is the method of impedance matching of a receiving antenna the same as the impedance matching of a transmitting antenna ?
You start with using port1 of the VNA to transmit a signal to the receiving antenna then get the S11 and antenna's impedance and then subsequently do the impedance matching ?
vfone
Advanced Member level 5
This is valid only if TX and RX use the same antenna, and the same frequency.
If TX and RX use the same antenna but different frequencies, situation is more complicated.
yashiro32
Member level 1
I am using this receiving antenna for GPS. Only a receiving antenna is required as this antenna is connected to a GPS receiver IC. So can i still apply the matching transmit antenna method to match my receiving antenna ?
vfone
OK, the receiver is GPS, but what network is your transmitter?
Toggle Sidebar
