Question on PORT reference and Z-port value in Ansys Circuit Nexxim - Inconsistant results between Transient and linear analysis ...
rdpdo2002
Member level 1
Member level 1
Hello,
Under Nexxim, when I configure my port 1 (Z=0, with reference to GND) with a sinusoidal source 1Vpp 4MHz and my port 2 (Z=10e9, with reference to GND) I got about G=-3db using Nexxim Transient Analysis :
So tell me if I am wrong, but for what I undertsand it's like having this :
Now When I remove the sin source on PORT1 and do a LNA 0-20 MHz, I got this. I still get the -3 db at 4MHz but offset by -140 db ...
For having good result, I need to reference PORT2 to PORT2 himself, using a Z=0 :
Why do I don't get same result using LNA and transient analysis when PORT2 is referenced to GND with Z=10e9 ?
Thanks you !
You do an s-parameters simulation, and one port is short circuited, other is open circuit.
What exactly you've been expecting ??
I don't understand why the same port2 configuration give me different result when I do LNA and when I do simple sinusoidal freq analysis ?
LaTeX Commands Quick-Menu:
