Question on LVDS transmitter
suhas_shiv
Full Member level 2
What is usually the input to a LVDS transmitter/driver? Most of the times it's a pulse, what is the Vih, Vil and common mode level(if any)?
Appreciate any response.
If I understood your question correctly, the Vil and Vih just depend on the digital logic you used. At trasnmitter side there is no spec on Vil/Vih.
I hope this site will help.
http://www.fairchildsemi.com/an/AN/AN-5017.pdf
output swing 250 mV to 450 mV
out common mode from 1.125 t0 1.375v
input swing is from 100 mV to 400 mV.
