1a2s3d4f
Member level 3
damping ratio second order sqrt(2)
Hi everyone,
I am confuse the different between when a system damping, it reduce the amplitude oscillation. We can specify the system to be critical damp (when the ratio is =1) or over damp (when ratio >1) or under damp (when the ratio is <1).
As for signal attenuation, it also reduce the signal amplitude (the signal attenuation and damping ratio are bout use to reduce the amplitude of a system).
I understand that the damping ratio is defined as signal attenuation factor to it resonant frequency.
I am so confuse the purpose of know both damping ratio and signal attenuation factor.
Thanks
Hi everyone,
Thanks
