Question of spectrum due to switching on GSM mobile phone.
Would you kindly explain to me what's the reason for the difference between signal measurement with un-signal measurement?
On un-signal mode, my GSM mobile phone was in test mode that only transmitter is working , the spectrum due to switching of +/-400KHz has about 6~8dB margin at the whole DCS band.
On signal mode, I connect the mobile with GSM test set and check the spectrum due to switching of +/-400KHz , we found there is only about 0~2dB margin on high band. eg Channel 885.
GSM test set : CMU200.
I can confirm test set is in normal state and in calibration date.
At the old PCB version, there are the good margin 6~8dB whether in signal mode or in un-signal mode.
New PCB and old PCB are embedding one software image.
No DC-DC , No LCD , only GSM kernel circuit (BB & RF)
I have checked all control signal , no difference between signal mode with un-signal mode. (timming & signal quality)
No way I can do now , Who can give me some suggestion?
Thank you!
