question in dealing with LPT IO pins
asrock
Junior Member level 3
hello every one
i have a question about reading lpt data that PIC control them ,
& i made a software to read from lpt ,,, but the issue in connecting PIC with lpt !
i mean >>> can i connect LPT pins directly to PIC pins (such as PORTA) ?!!
or are there any equipments that i must connect before ?
i use PIC16f877 & MikroC ,,,
so any one here can help me with any schematic plz
gratings :)
Maybe this thread will give you some help to find out: https://www.edaboard.com/threads/273541/
Enjoy your design work!
thanks a lot mr.HTA for ur link
here i draw a schematic how to change the pin1 of lpt as PIC rb0 ,,
when i trigger bc337 , the state of pin1 is "1" , else state is "0"
So is this schematic right?? ,, i don't test it in fact ,but i would know if it is right ,,
what's is your opinion ?
Hi Asrock,
Pin 2 of the printer port is an output and if you want to generate an interrupt signal on PIC rbo it need to drive the base of the transistor via a resistor to limit the current. The collector should e connected via a resistor to 5V and drive the PIC rb0 input.
