Question about VCO output
Adam2008
Member level 1
Hi All,
The amplitude of the output waveform of the Cross couled VCO is very large(6V) at begining, then it turned to be a equal amplitude waveform(0.8V ~ 1.6V), what could be the reason of the super large amplitude at the beginning?because of iniitial condition?
The output wavform is between 0.8V and 1.6V, how can I move it to between 0V and 0.8V? or between -0.4V and 0.4V?
Thanks.
khouly
Advanced Member level 5
EGYPT
the inductor man . when u switch the on and off and there is an inductor there will be overshoot
khouly
    Adam2008
Adam2008
Member level 1
Thanks. khouly.
How can I solve this problem?
Mazz
Advanced Member level 2
Usually not a big problem for two reason:
-Real Q is lower than schematic one, so real transient amplitude is lower
- it is very fast (few hundred of ns) and doesn't damage the transistors or reduce their reliability.
For DC scaling you can use an NMOS follower or DCblock and make a different bias.
I hope it can help.
Mazz
    Adam2008
