Question about RJs and network cables
Hooda
Member level 3
Network Cable
hi
i made a home network .for making RJ 's the network cables
1)does it differs in the colors of the 8 wires in the Network cable to connect between the 2 RJ of the terminals ..?
2)for example , orange is wire no.1 should be no.1 in the second terminal of the Cable?
thanks in advance
gdaporta
Member level 5
Argentina
Re: Network Cable
Hooda said:
hi
thanks in advance
Hooda:
Exists two EIA/TIA specifications, EIA/TIA 568-A and EIA/TIA 568-B. If are going to connect only two PC without a Hub or Switch, you have to make a Crossover cable.
You can make the cable following by this diagram:
PIN---- RJ-45 (1)-----------RJ-45 (2)
-1------White/Orange------White/Green
-2------Orange--------------Green
-3------White/Green--------White/Orange
-4------Blue------------------Blue
-5------White/Blue----------White/Blue
-6------Green----------------Orange
-7------White/Brown--------White/Brown
-8------Brown----------------Brown
Best R.
Guille
Added after 17 minutes:
Hooda:
I found two documents in my PC, one is useful to know what kind of cable you need for each app. And the other is an image, on it, you have the front seen of female RJ connectors and specs.
Best R. again.
Guille
    Hooda
Hooda
Member level 3
Re: Network Cable
thanks alot this table is illustrative
Excuse me for trivial Question :?:
in cross over are the 2 terminals are identical ..?i.e. can i alternate both terminals from Router to PC or ViceVersa
thanks ; regards
Cluricaun
Advanced Member level 2
Re: Network Cable
Hi
If you like to make a crossover cable from an ordinary one you only change at one side. What you are after is to change so the Tx at one side will be a Rx forthe other computer.
Whas this what you asked for?
Cl
    Hooda
ehsanelahimirza
Full Member level 6
Re: Network Cable
cross cable can b used for peer to peer connection i.e. 1 pc directly connected to 2nd
but if u want to use a networking HUB also then dont bother about cross/straight
u should prefer straight then i.e. if orange is first then it is first in each case same 2 3 4 5 6 7 8 wire also
    Hooda
Hooda
Member level 3
Re: Network Cable
thanks alot your replies answered me
but can anyone till me what is the need for crossover ..? what does it make ..?
my little knowledge that cable has 4 pairs for data transfer why crossovering them ..?
Cluricaun
Re: Network Cable
Hi
read my post and you find the answer. If you do not change this the computer will try to eceive on a cable that the other PC also listens to.
Cluricaun said:
Hi
What you are after is to change so the Tx at one side will be a Rx for the other computer.
Cl
Anno
South Africa
Network Cable
woot gdaporta
Great post! hope you got a few points for that one!
gdaporta
Member level 5
Argentina
Re: Network Cable
Thank´s Anno for your reply and thank´s Hooda for you "Helped point".
I just want to help. I hope you solve your problem.
Hooda wrote: "...in cross over are the 2 terminals are identical..."
Yes, Ethernet 10-BaseT and 100-BaseT do not use pins 4, 5, 7 and 8. You can test it, make you cable only with pins 1, 2, 3 and 6. It must works fine. But it´s recommended to use al the wires.
Best R.
Guille
    Hooda
