question about reference generator
danda821
Full Member level 2
Full Member level 2
Can anyone explain the amplifier feedback polarity in the following circuit? Can I change the polarity? Thank you.
in the opamp bandgap, there are both positive and negative feedback.
you can not change the polarity of the opamp. because at the startup, the negative terminal voltage is bigger than the positive terminal, so the opamp output voltage will be low, than the circuit will startup.
first, you can not change the polarity because the stability.
the positive loop, minus input of op->output of op->pmos gate->pmos drain (left)
the negative loop plus input of op->output of op->pmos gate->pmos drain(right)
You should ensure the stability of the bandgap circuit, in this circuit, there are two feedbacks, one positive (negative input of A1 and M1) and one negative (positive input of A1 and M2), and at this condition, the negative feedback extent is deeper than the positive one, which ensures the stability.
hope it helps!
I think this pic was from Razavi.. right?
(1)there are 2 feedback loops ( both positive and negative feedback)
(2)A loop want stable-->negative feedback>positivefeedback
(3)feedback factor analysis
hope it helps!
