Question about quality factor and inductance of coils when using HFSS, Maxwell3D, and Q3D
Tyrion
Newbie
Currently, I am designing wireless power transfer coils and want to know the Q factor of my coils. I tried HFSS, MAXWELL3D and Q3D. Their inductance are all different. Which one is more accurate for me to use?
My coil is a planar spiral coil with 40turns, 25mm outer diameter, 5mm inner diameter.
The HFSS result is usually a few nH and -nH varying by frequency. The Maxwell3D is about 2uH and the Q3D gives me about 24uH.
volker@muehlhaus
Advanced Member level 5
The problem is that you might have used some of the tools incorrectly.
24µH seems realistic.
I have simulated many planar coils in EM tools, and recommend to use this online calculator to estimate results:
For your low WPT frequencies, the simple calculator is quite accurate. Width and spacing determine the inner size and that has a large effect on inductance.
Good luck!
Volker
