neazoi
Advanced Member level 6
- Joined
- Jan 5, 2008
- Messages
- 4,157
- Helped
- 13
- Reputation
- 26
- Reaction score
- 15
- Trophy points
- 1,318
- Location
- Greece
- Activity points
- 37,198
In the USA we do not put a fuse or a switch in the 120vac neutral line. Our neutral is connected to ground at the circuit breaker box.
Our 240 volt power has two hot lines and it gets fused and switched in both lines.
Actually neutral and earth are same if the fuse in the neutral side blown there is a more chance of shock that is the reason for avoiding fuse in neutral side.
If you don want to do compromise the change in L and N means use three pin socket.
also can you post a image of three pin socket used in UK.
fine. If you use a two pin cable then you will need two fuses and DPST. The DPST is to ensure the phase is removed in off condition and two fuses because we don know which wire is going to be phase on equipment side.
Thank you, that is what I initially thought. Thanks a lot!
Also, how should I connect an indicator neon buld (on/off) at the input?
