Lord Loh.
Full Member level 4
EPROM Help...
I hope this is the right forum to ask this sort of a question....
I would read a particular term in the datasheet of 27256 EPROM...
It said, 168±8 burn-in (125°c)hr what does this mean ?
Also, I would like to know if an EPROM requires UV light during the programming or only during erase operations.
Is there a limit on the number of times an EPROM may be programmed ?
And last, Can an EPROM be programmed on a bread board ? by constantly changing connections, and giving the final puse of Vcc/Vpp and chip select ?
Thanks in advance...
