zouyong
Newbie level 6
[SOLVED] question about primetime PX: about using create_power_waveforms
Hi:
From a document named “PrimeTime® PX Methodology for Power Analysis v1.2”, it says "Unless you set power_force_saif_flow to TRUE, create_power_waveforms can not be used."
Then I "set set power_force_saif_flow TRUE", but still this "create_power_waveforms" can't be used.
pt_shell> create_power_waveforms
Error: Command 'create_power_waveforms' is not enabled as default. Set power_ui_backward_compatibility to TRUE to enable this command. (UIPWR-002)
pt_shell> set power_ui_backward_compatibility TRUE
Warning: Detected use of obsolete/unsupported feature. Variable
power_ui_backward_compatibility will not be available
in a future release of the application.
Please update your command usage accordingly.
Error: Can not enable or disable UI backward compatibility after power analysis commands have been issued. (UIPWR-008)
Error: can't set "power_ui_backward_compatibility":
Use error_info for more info. (CMD-013)
Can anybody tell me how to use this create_power_waveforms?
If this create_power_waveforms is unsupported anymore, is there any new command I can use to figure out the power waveforms?
Primetime Version: F-2011.06-SP1
Many thanks!!!
Using set power_analysis_mode time_based and update_power, I can get the waveforms now.
Hi:
Many thanks!!!
