jeremygb
Newbie level 3
Not sure if this post is in the correct category.
I am a data center technician and I routinely deal with hot swappable power supplies in servers. This is what I see happen. The server's hardware monitoring processor will send out an alert for a failed power supply. The amber warning light on the power supply will be on and the event log will indicate a failed power supply. All very normal sequence of events. One thing the I am curious about is after re-seating the power supply, it will come back on with the green status light and continue working. This will only last anywhere from 2 to 8 hours when it will fail again. Re-seating the power supply again yields the same behavior. This will happen with almost every power supply failure that I have encountered.
I get that from a computer hardware perspective that the monitoring system detects a pre-defined failure condition and takes the appropriate action. The re-seating of the powers supply somehow clears this failure condition. Can someone tell me what is happening here from an electronics perspective to cause the power supply to get a temporary second wind after being re-seated?
Thanks for looking.
Jeremy
Thanks for looking.
Jeremy
