Question about particular HDL code
rickyice
Junior Member level 2
if(a>5)
b=1;
else
b=0;
now, if (input)a=x,and then b=???
hdl questions
Here, b will get "0" as the if condition fails here. Generally in the case of failing "if" .... else will get executed."else" doesn't look for any condition..failing of "if" is enough for "else" to get the execution.
Re: hdl questions
polukir is right,
thank you
Re: hdl questions
Why dont you simulate and check in waveform.
hdl questions
i think it depend on simulation tools
Re: hdl questions
i did it
Re: hdl questions
If this is for a non-synthesizable code, then it's going to have a value of 0. but if this is a synthesizable code then after synthesis it's still 'X'.
Re: hdl questions
it's definitely 0
Re: hdl questions
hi,
f(a>5)
b=1;
else
b=0;
if a is greater than 5, b wiil be equal to 1...................
if a is less than or equal to 5 or others(like x,z...), b will be equal to zero
Re: hdl questions
It is not a matter of synthesis or simulation.....
In Synthesis it will take a MUX and a comparator....so it will show X if u simulate synthesized netlist with
input 'X'.
But in rtl code it should give output '0'.
Praveen.
hdl questions
stevepre is correct. Put it in another way: if you're answering your final test, write down 'b = 1' if you're facing real problem in your design, particularly for PL simulation, you will get 'x'.
hdl questions
it's definitely 0 because if statement will see only condition is satisfied or not , and X will be treated as condition is not satisfied so b will be always 0.
Re: hdl questions
yups it wil b zero!!
