Electrojosh86
Member level 3
- Joined
- Jun 20, 2013
- Messages
- 67
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 6
- Activity points
- 570
I figured I'd ask another question since you guys on this site helped me out awhile back. I started making FM low power transmitters after getting some pointers from a posting on this site and fixing my mistakes and now I am cranking them out and all work, but there is one question that I did not ask. When it comes to the output stage, usually the buffer, I was wondering if you have to use a RF transistor or just any old transistor in place.
Example:
https://electronics-diy.com/tx200.php
Say I put an RF Transistor in place of Q1 and just a plain ol' 2n2222 ,2n3904, or 2n5088 NPN's on place of Q2. Will Q2 still work as advertised? Or should both be RF just in case?
Also, unrelated question. What is a better way of etching little pads or, as I call them, tracks into PCB? Like the radioshacks doublesided PCB. I use a Dremel with a small etcher bit and it works pretty well but when it comes to smaller PCB's I want something more percise. Simply cutting it with a razor seems not to work though. Unless heated?
Thank you! Also, take it easy on me. Just trying to learn.
Example:
