Question about mix-simulation problem using Cadence
xiexi
Member level 4
cadence mix simulation
When I use hspiceSVerilog to do mix-signal simulation, after the netlist is generated, the simulation procedure is stopped and icfb saying"+vmslave:No such file or directory".
I don't know why, may be it is the workstation system problem, so pls give me some suggestion and instruction, thanks ahead.
Fom
Advanced Member level 2
Taiwan
I think to use hspiceS or hspiceSVerilog you need additional licence that is not included in standard IC5.0 package.
