question about low power LDO
alasliu
Junior Member level 1
dear all i want to design a low power LDO. but i dont know which structure to use.
thank you
You can use structure with power PMOS transistor.
thanks
LDO used in soc
0-20mA transient response
dip< 50m
PSRR > 40dB at 1M
about 1uF ceramic cap
Added after 59 minutes:
have used PMOS
no
Added after 4 minutes:
please giveme some advice thank you
which spec are u facing problem?
what is quiescent current?
Added after 1 minutes:
if ur load is also on-chip, then external cap will be of not much use!
