Question about lookup table in VHDL
EDA_hg81
Advanced Member level 2
lookup table vhdl
I want to find an efficient way to build the compact lookup table inside FPGA based on following code:
Currently I detect all input 64 formats by using “if” and “elsif”, but this way is too timing consuming.
If I use ROM to build the lookup table, so much memory space is going to be wasted
Do you have any idea about how to build a much more efficient and compact look up table inside FPGA?
Case state is
When idle     =>
if    ( trigger = '1' and formatdata( 31 downto  28) = x"6" and formatdata( 27 downto 16)  = x"4D3"  and x"06c8" >= formatdata( 15 downto  0 )     and formatdata( 15 downto 0 ) >= x"06C6")then
elsif    ( trigger = '1' and formatdata( 31 downto  28) = x"6" and formatdata( 27 downto 16)  = x"4D3"  and x"06c8" >= formatdata( 15 downto  0 )  and formatdata( 15 downto 0 ) >= x"06C6")then
end if;
When output   =>
When others   =>
End case;
Very appreciate for you suggestions.
FvM
Super Moderator
Staff member
Bochum, Germany
what is (look-up) table in vhdl
Any indications for this assumption? The FPGA compiler is minimizing the decoder logic and implements it in logic cells. This is generally the fastest way to implement the decoder.
Because your input vector is 32 bit size, it effectively can't be decoded by a ROM table without previous minimization.
    EDA_hg81
EDA_hg81
how to make look-up table in vhdl
I have changed to the following:
 case checker_state is
                when checker  =>
                     ack_reg        <= '0';
                     resetformat    <= '0';
                     if ( trigger = '1' )  then
                        case formatdata is
                             when x"64D206C6"  => format_reg := 1;
                             when x"64D206C7"  => format_reg := 1;
                             when x"64D206C8"  => format_reg := 1;
                             when x"64D306C6"  => format_reg := 1;
                             when x"64D306C7"  => format_reg := 1;
                             when x"64D306C8"  => format_reg := 1;
                             when x"345D0779"  => format_reg := 2;
                             when x"345D077A"  => format_reg := 2;
                             when x"345D077B"  => format_reg := 2;
                             when x"345E0779"  => format_reg := 2;
                             when x"345E077A"  => format_reg := 2;
                             when x"345E077B"  => format_reg := 2;
                             when x"644007AE"  => format_reg := 3;
                             when x"644007AF"  => format_reg := 3;
                             when x"644007B0"  => format_reg := 3;
                             when x"644107AE"  => format_reg := 3;
                             when x"644107AF"  => format_reg := 3;
                             when x"644107B0"  => format_reg := 3;
                             when x"34E106A9"  => format_reg := 4;
                             when x"34E106B0"  => format_reg := 4;
                             when x"34E106B1"  => format_reg := 4;
                             when x"34E206A9"  => format_reg := 4;
                             when x"34E206B0"  => format_reg := 4;
                             when x"34E206B1"  => format_reg := 4;
                             when x"342307E4"  => format_reg := 5;
                             when x"342307E5"  => format_reg := 5;
                             when x"342307E6"  => format_reg := 5;
                             when x"342407E4"  => format_reg := 5;
                             when x"342407E5"  => format_reg := 5;
                             when x"342407E6"  => format_reg := 5;
                             when x"33A308F6"  => format_reg := 6;
                             when x"33A308F7"  => format_reg := 6;
                             when x"33A308F8"  => format_reg := 6;
                             when x"33A408F6"  => format_reg := 6;
                             when x"33A408F7"  => format_reg := 6;
                             when x"33A408F8"  => format_reg := 6;
                             when x"63A508F6"  => format_reg := 7;
                             when x"63A508F7"  => format_reg := 7;
                             when x"63A508F8"  => format_reg := 7;
                             when x"63A608F6"  => format_reg := 7;
                             when x"63A608F7"  => format_reg := 7;
                             when x"63A608F8"  => format_reg := 7;
                             when x"444007AC"  => format_reg := 8;
                             when x"444007AD"  => format_reg := 8;
                             when x"444007AE"  => format_reg := 8;
                             when x"444107AC"  => format_reg := 8;
                             when x"444107AD"  => format_reg := 8;
                             when x"444107AE"  => format_reg := 8;
                             when x"631A0A83"  => format_reg := 9;
                             when x"631A0A84"  => format_reg := 9;
                             when x"631A0A85"  => format_reg := 9;
                             when x"631B0A83"  => format_reg := 9;
                             when x"631B0A84"  => format_reg := 9;
                             when x"631B0A85"  => format_reg := 9;
                             when x"332008F4"  => format_reg := 10;
                             when x"332008F5"  => format_reg := 10;
                             when x"332008F6"  => format_reg := 10;
                             when x"332108F4"  => format_reg := 10;
                             when x"332108F5"  => format_reg := 10;
                             when x"332108F6"  => format_reg := 10;
                             when x"332008B4"  => format_reg := 11;
                             when x"332008B5"  => format_reg := 11;
                             when x"332008B6"  => format_reg := 11;
                             when x"332108B4"  => format_reg := 11;
                             when x"332108B5"  => format_reg := 11;
                             when others       => format_reg := 4095;
                        end case;
                        checker_state  <= ckredund;
                     end if;
                when ckredund   =>
How do you think this style, if this style has the same working efficiency as last one?
Thanks.
FvM
Super Moderator
Staff member
Bochum, Germany
lookup table in vhdl
Yes I think so, provided, the expressions are equivalent. You can check, if you compile it with a FPGA hardware compiler, e.g. A.ltera Q.uartus and compare the consumed logic resources.
    EDA_hg81
EDA_hg81
vhdl lookup table
Do we have any other structures which can save resource for lookup table by VHDL?
Thanks.
tlp71@hotmail.com
Full Member level 4
look up table in vhdl
yes, you have.
you can use a ram module.
    EDA_hg81
FvM
Super Moderator
Staff member
Bochum, Germany
lookup table fpga
Yes, generally. In the present case, there may be an issue of too many input bits, as previously discussed.
    EDA_hg81
