pblakeney
Newbie level 2
Hi
I have more of a general question. Is the LM392N have an open collector for its output?
I am interested in using the comparator part of the circuit (Amplifier A).
If I place 12V on the V+ (pin eight) and I have the non inverting input voltage greater than the non inverting input voltage does that mean the ouput would be floating?
Let's say the Non Inverting input has 6 volts and the Inverting input has 5 volts and the output is connected to an Led through a resistor (say 680 ohms), would the LED light up?
If I think I understand this comparator my gues would be that it would not. And I would have to use a pull-up resistor on the output. However if I did this then wouldn't there be a voltage divider and the LED might not light up or glow only dim because of the pull-up resistor and even if I did find a pull-up resistor that would cause the LED light to glow normally wouldn't it be on all of the time unless the inverting input became greater than the non inverting input?
Am I understanding this correctly?
Actually what I am trying to do is have the output of a comparator pass to the input of another comparator (comparator A output being connected to the non inverting input of comparator B). If I understand this comparator correctly if the non inverting input on comparator A is greater than the inverting input of comparator A then I would have no signal at all for the inverting input of comparator B. If I use a pull-up resistor on the output of comparator A then the inverting input of comparator B will be high all of the time unless the non inverting input of comparator A falls below the inverting input of comparator A.
If this is indeed the case, would I be better off using an Op Amp with no feedback so that I could get the high output signal needed when the non inverting input is greater than the inverting input?
Thanks for any help of suggestions in advance!
