question about Linux installation (can not start with Linux)
easy4880
Newbie level 5
hello~~~ everyone
I installed linux on my laptop. but when I finished installation and restart my computer, my computer can not go into linux OS. and there are some error report as follows:
ide: Assuming 33MHZ system bus speed for PIO modes; override with ide bus=xx
PCI_IDE:unknown IDE controller on PCI bus 00 device f9, VID=8086,DID=24ca
PCI:Device 00:1f.1 not available because of resource collisions
PCI_IDE:(ide_setup_pci_device:) Could not enable device
The partitions I use is one root(/), one boot(/boot) and one swap partition(twice size of my RAM)
Does anyone meet this problem before? Can anyone help me?
I am waiting online. thanks
Re: question about Linux installation (can not start with Li
Hello!
You have what version Linux?
hi, the version is Linux 8.0
no one can solve this problem??
I think you have an old version of Linux. If this is Redhat 8, it is considered very old. Try newer version, like Fedora Core 5, and check if your laptop is suppored in it, before trying to install.
Please tell me your hardware (CPU, HD). Maybe your hardware is very new (such as SATA HD).
it is related with my lagtop's hardware?
The problem can be due to incompatiability between the old OS andthe new hardware.
Its better you try REDHAT 9 or 10, and then see whether the problem persists
Shaikh Sarfraz
>PCI_IDE:unknown IDE controller on PCI bus 00 >device f9, VID=8086,DID=24ca
>PCI:Device 00:1f.1 not available because of resource >collisions
your PCI_IDE device does not work well, maybe your linux version dont have it's driver, you may try other newer linux distributions
