Question about hot carrier effect
sirricky
Newbie level 6
how dose the LDD structure work on avoiding the hot carrier effect in mos??
not quite clear, thanks
Low doping decrease the electeric field and hence decrease the hot carrier effect
y not using all low doped diffusion , to decrease the parasitic resistance
The below description may clarify your doubt, and it is quoted in the "the art of analog layout".
The strong electric field across the pinched-off channel of a saturated MOS transistor causes hot carrier degradation. The electric field intensity diminishes if the depletion region can somewhat be widened. In a conventional transistor, the depletion region cannot intrude to any significant extent into the heavily doped drain. If the drain diffusion is more lightly doped, then the depletion region can extend into the drain as well as into the channel and the electric field intensity will decrease. Such lightly doped drain(LDD) transistors can withstand substantially higher drain-to-source voltages than can conventional single doped drain(SDD) devices
LDD = Lateral Double Diffusion or Lightly Doped Drain?
I am already a little bit confused.
In LDD the doping is lower.
Hot electron effects can be reduced by lowering the doping concentration
