obrien135
Full Member level 5
- Joined
- Nov 10, 2009
- Messages
- 240
- Helped
- 5
- Reputation
- 10
- Reaction score
- 5
- Trophy points
- 1,298
- Location
- Connecticut
- Activity points
- 3,259
Hi again. As I was informed on another thread, certain high speed op amps should not be used to drive a capacitive load. I built a 4 stage amp using op amps that have caps between stages for coupling. Should I short them out or remove them and replace with a short, or would the biasing of adjacent stages throw each other off? If it is a chip that doesn't have an offset null input, does this mean that if ones stage is biased correctly it will have a 0V (or for single supply applications, 1/2 supply voltage) at it's output. If this was the case , would this be sufficient to not upset the successive stage if it is biased the same way (with 0V or 1/2 supply at + and - inputs and output)? If not how would I correct this problem? With a chip that has an offset null ?
Also if an op amp with a single supply is used to drive a transformer with one end of the primary connected to ground, would you need some kind of buffering , such as an emmitor follower to drive the transformer, so it doesn't upset the biasing of the op amp (if you don't use a coupling capacitor)?
George
George
