eepty
Full Member level 2
Relay is normally rated at DC voltage 12V, 24V, 48V........
When the DC voltage rating increase from 12V to 24V, the manufacturer always increase the coil resistance by 4 times, say from 200R to 800R, to keep the power rating the same.
However, If the coil resistance increase by 4 times and the DC voltage increase by 2 times, the current have to decrease by 2 times. Does it affects the magnetic field? As a result, does it decrease the contact quality?
Thank you
Thank you
