Tisapphire
Newbie level 2
usually for CPW, the middle metal line is used as the signal line and the other two on each side are grounded.
In my set up, I use one line on the side (say, the left one) to connect to the input signal, and ground the center line and the right line.
My question is, how should I analyze the modes in this configuration? should it be CPW with even mode? or should it be considered as two coupled transmission lines/slot lines?
Thank you so much!
Thank you so much!
