Question about Common-source and Common-gate structure
abcyin
Full Member level 4
Hi, all
I just found that the gain of Common-source and common-gate structure is almost equal to each other, it's about gm*RL, regardless of the sign of the gain.
And because of the body effect, the gain of the CG structure is a little larger than the CS one, Even the bandwidth of CG is always larger than the later, But why we always use the common-source structre instead of the common-gate structure?
the second question is that why don't we use the CG structure to form operational amplifier?
Thx in advance!
you mean a smaller input resistor and capacitor will show a larger bandwidth for the common-gate structure?
And...if the amplifier is in series with other blocks, then the former stage's gain will be reduced by the input impedance of the common-gate stage, is it right?
solidstate means that for CS the input is purely capacitive, while CG has very low input impedance
