May 19, 2008 #1 A anujaa Junior Member level 1 Joined Oct 30, 2007 Messages 15 Helped 1 Reputation 2 Reaction score 0 Trophy points 1,281 Activity points 1,375 Hello all, I have got one Eq, for PT 100 for negative temperature: Rt = R0(1+aT+bT²+cT³(T-100)) R0 = 100 ohms Rt is resistance of PT100 a=0.003069 b=0.000000587 c=4.27x10^-12 T temperature so form this eq what will be the equation for T? means T=? Thanks in advance
May 19, 2008 #2 FvM Super Moderator Staff member Joined Jan 22, 2008 Messages 52,487 Helped 14,756 Reputation 29,794 Reaction score 14,121 Trophy points 1,393 Location Bochum, Germany Activity points 298,375 pt100 +equation You can use different approximations, depending on the temperature range and the intended accuracy. For a 0-400°C, this polynomial may be used t = 1.008E-06(r-100)³ + 9.441E-04(r-100)² + 2.560E+00(r-100) Good for -20 to 400 as well
May 19, 2008 #3 A anujaa Junior Member level 1 Joined Oct 30, 2007 Messages 15 Helped 1 Reputation 2 Reaction score 0 Trophy points 1,281 Activity points 1,375 equação pt100 @ FvM The temperature range is -20 to 400ºC
