Question about a 32 bit pointer in embedded C
123music
Junior Member level 1
I have a long *temp and int *temp1(assuming long is 4 bytes and int is 2 bytes and initialized with some memory address)
if i want to write 2 bytes into temp1 from temp, i will write as
*temp1 = *(int*)temp;
what if i want to write 2 bytes into temp from temp1??can i write as
*(int*)temp = temp1??
Is it allowed in embedded C?
But i think the second case we cannot call it as type casting..What do we call it then?
millwood
Advanced Member level 3
32 bit pointer
whether someone is a 32-bit pointer has nothing to do with if the object it points to is a 32-bit type or not.
"*temp1 = *temp;" takes the value temp points to (a 4-byte type) and gives it to the object temp1 points to (a 2-byte type).
"*temp=*temp1;" does the opposite.
"*temp=temp1;" takes the value of temp1 (a pointer) and gives it to the object temp points to). This operation is almost meaningless.
