Query om Pressure Transducer. Plz Help..! Its urgent
pratibha m d
Junior Member level 3
Hi All,
I want to get some information regarding where can I buy "Impedance pressure transducer of 5 mm in diameter and 1mm thick". I tried to find in google. But couldn't get any information. Kindly help me. Its urgent.
Thanks
Are you looking for strain gauge type sensor? How about Piezoresitive sensors? You will find in any MEMS book. I can hint you something on this. You can use a piezoresistor in a bridge circuit with three other normal resistors such that without any pressure load the bridge is balanced. With pressure the resistivity of the piezoresistor changes, changing the output signal linearly with the resistance. The output signal is a measure of the pressure.
You will find the details in any MEMS book. Or search for piezoresistive transducers in the internet.
Thank u so much. But I want to know if I can get it as a product. Its required in dental application.
Thanks
We use Fujikura pressure sensors to measure up to 15 PSI.
