cks3976
Full Member level 6
Dear Gurus,
We are designing a 12-layers PCB that should carry very high current (70A) from a 48V source. I have reserved 8 layers for Power and Ground signals. Mounting holes and thru-hole pins on the board have caused significant void areas on all these power planes. Dimension of the CB is 17.0" X 1.80".
A minimum of 900 mils of conductor width is needed on 2 ounce copper to carry a total of 76 Amperes of current as per some calculator. But due to these voids I am getting a minimum of 200 mils of conductor width at some places of the PCB. We have multiple power planes on the PCB with almost similar copper area on multiple layers that are stitched using vias (16 mils drill and 32 mils pad).
Am I doing right, or are there anything that I am missing here?
Any help in this is greatly appreciated.
