narayani
Full Member level 2
- Joined
- Aug 15, 2014
- Messages
- 136
- Helped
- 0
- Reputation
- 0
- Reaction score
- 1
- Trophy points
- 1,298
- Activity points
- 2,360
I want to check the stability of the transistor using the available transistor S-parameters, am using the Avago ATF54143 transistor to my work.
I have checked the stability of the transistor using the following conditions
K > 1, and B1 >0
If above these conditions are satisfied simultaneously, then we can say that transistor is unconditionally stable. Otherwise it is unstable.
Other than this, can we check the stability of the transistor using Smith chart. How we can check stability of the transistor using Smith chart drawing Software in ADS 2011.10.
Can you help me.
K > 1, and B1 >0
Can you help me.
